COSTOTest: a tool for building and running test harness for service-based component models (demo) - ATLANMOD Accéder directement au contenu
Early testing reduces the cost of detecting faults and im- proves the system reliability. In particular, testing compo- nent or service based systems during modeling frees the tests from implementation details, especially those related to the middleware. COSTOTest is a tool that helps the tester dur- ing the process of designing tests at the model level. It sug- gests the possibilities and the lacks when (s)he builds test cases. Building executable tests is achieved thanks to model transformations.
isstatd2016.pdf (533.11 Ko) Télécharger le fichier
hal-01436067 , version 1 (26-04-2017)
Pascal Andre, Jean-Marie Mottu, Gerson Gerson Sunyé. COSTOTest: a tool for building and running test harness for service-based component models (demo). ISSTA 2016 Proceedings of the 25th International Symposium on Software Testing and Analysis, Jul 2016, Saarbrücken, Germany. pp.437-440, ⟨10.1145/2931037.2948704⟩. ⟨hal-01436067⟩
387 Consultations
167 Téléchargements
