Model transformation on distributed platforms : decentralized persistence and distributed processing - ATLANMOD Accéder directement au contenu
Thèse Année : 2016
Transformation de modèles sur plates-formes réparties : persistance décentralisée et traitement distribué
Model-Driven Engineering (MDE) is gaining ground in industrial environments, thanks to its promise of lowering software development and maintenance effort. It has been adopted with success in producing software for several domains like civil engineering, car manufacturing and modernization of legacy software systems. As the models that need to be handled in model-driven engineering grow in scale, it became necessary to design scalable algorithms for model transformation (MT) as well as well-suitable persistence frameworks. One way to cope with these issues is to exploit the wide availability of distributed clusters in the Cloud for the distributed execution of model transformations and their persistence. On one hand, programming models such as MapReduce and Pregel may simplify the development of distributed model transformations. On the other hand, the availability of different categories of NoSQL databases may help to store efficiently the models. However, because of the dense interconnectivity of models and the complexity of transformation logics, scalability in distributed model processing is challenging. In this thesis, we propose our approach for scalable model transformation and persistence. We exploit the high-level of abstraction of relational MT languages and the well-defined semantics of existing distributed programming models to provide a relational model transformation engine with implicit distributed execution. The syntax of the MT language is not modified and no primitive for distribution is added. Hence developers are not required to have any acquaintance with distributed programming.We extend this approach with an efficient model distribution algorithm, based on the analysis of relational model transformation and recent results on balanced partitioning of streaming graphs. We applied our approach to a popular MT language, ATL, on top of a well-known distributed programming model, MapReduce. Finally, we propose a multi-persistence backend for manipulating and storing models in NoSQL databases according to the modeling scenario. Especially, we focus on decentralized model persistence for distributed model transformations.
Grâce à sa promesse de réduire les efforts de développement et maintenance du logiciel, l’Ingénierie Dirigée par les Modèles (IDM) attire de plus en plus les acteurs industriels. En effet, elle a été adoptée avec succès dans plusieurs domaines tels que le génie civil, l’industrie automobile et la modernisation de logiciels.Toutefois, la taille croissante des modèles utilisés nécessite de concevoir des solutions passant à l’échelle afin de les traiter (transformer), et stocker (persister) de manière efficace. Une façon de pallier cette problématique est d’utiliser les systèmes et les bases de données répartis. D’une part, les paradigmes de programmation distribuée tels que MapReduce et Pregel peuvent simplifier la distribution de transformations des modèles (TM). Et d’autre part, l’avènement des base de données NoSQL permet le stockage efficace des modèles d’une manière distribuée. Dans le cadre de cette thèse, nous proposons une approche pour la transformation ainsi que pour la persistance de grands modèles.Nous nous basons d’un côté, sur le haut niveau d’abstraction fourni par les langages déclaratifs (relationnels) de transformation et d’un autre côté, sur la sémantique bien définie des paradigmes existants de programmation distribués, afin de livrer un moteur distribué de TM. La distribution est implicite et la syntaxe du langage n’est pas modifiée (aucune primitive de parallélisation n’est ajoutée). Nous étendons cette solution avec un algorithme efficace de distribution de modèles qui se base sur l’analyse statique des transformations et sur résultats récents sur le partitionnement équilibré des graphes. Nous avons appliqué notre approche à ATL, un langage relationnel de TM et MapReduce, un paradigme de programmation distribué. Finalement, nous proposons une solution pour stocker des modèles à l’aide de bases de données NoSQL, en particulier au travers d’un cadre d’applications de persistance répartie.
Benalallam_A_12_2016.pdf (1.52 Mo) Télécharger le fichier
tel-01427197 , version 1 (05-01-2017)
  • HAL Id : tel-01427197 , version 1
Amine Benelallam. Model transformation on distributed platforms : decentralized persistence and distributed processing. Software Engineering [cs.SE]. Ecole des Mines de Nantes, 2016. English. ⟨NNT : 2016EMNA0288⟩. ⟨tel-01427197⟩
580 Consultations
702 Téléchargements
