Modélisation, analyse et classification de motifs structuraux d'ARN à partir de leur contexte, par des méthodes d'algorithmique de graphes - BioInformatique Access content directly
Theses Year : 2022
Modeling, analysis and classification of RNA structural motifs from their context, using graph algorithmic methods
In this thesis, we study the structural context of RNA structural motifs in order to make progress in their prediction. Indeed, some RNA motifs, which are substructures appearing recurrently in RNA structures, remain difficult to predict, because of the presence of non-canonical interactions in these motifs, and because of the distance on the primary sequence between the different parts of these motifs. We therefore model the topological structural context of these motifs by graphs, and compare the contexts of the different occurrences using several graph algorithms. We then classify the motif occurrences according to their topological context similarities and according to their 3D context similarities, using an overlapping clustering algorithm.First, we show on a dataset of three structural motifs that the observed similarities between the topological contexts are consistent with the similarities between the 3D contexts. This indicates that the topological context may be sufficient to determine the 3D context for these three motifs.In a second step, we study several classifications of occurrences of the A-minor motif, according to 3D context similarities. We observe that 3D context similarities exist between non-homologous occurrences, which could be a sign of an evolutionary convergence phenomenon. Moreover, we observe that some parts of the 3D context seem to be better conserved than others between non-homologous occurrences.In a third step, we study the predictive ability of the common topological context of A-minor motif occurrences, sharing similar 3D contexts, as well as the predictive ability of a sequence signal on these same occurrences. To this end, we study the occurrence of this topology and sequence in RNA structures in the absence of A-minor motifs. We conclude that the topology and the sequence represent a good signal for the majority of the studied classes.
Dans cette thèse, nous étudions le contexte structural de motifs structuraux d'ARN dans le but de progresser vers leur prédiction. En effet, certains motifs d'ARN, sous-structures apparaissant de façon récurrente dans les structures d'ARN, restent difficiles à prédire, en raison de la présence d'interactions non canoniques dans ces motifs, et en raison de la distance sur la séquence primaire séparant les différentes parties de ces motifs. Nous modélisons ainsi par des graphes le contexte structural topologique de ces motifs, et comparons les contextes des différentes occurrences en utilisant plusieurs algorithmes de graphes. Nous classifions ensuite les occurrences de motif selon leurs similarités de contexte topologique et selon leurs similarités de contexte 3D, à l'aide d'un algorithme de clustering recouvrant.Dans un premier temps, nous montrons sur un jeu de données de trois motifs structuraux que les similarités observées entre les contextes topologiques sont cohérentes avec les similarités entre les contextes 3D. Cela indique que le contexte topologique peut être suffisant pour déterminer le contexte 3D pour ces trois motifs.Dans un deuxième temps, nous étudions plusieurs classifications d'occurrences du motif A-minor, selon des similarités de contexte 3D. Nous y observons que des similarités de contexte 3D existent entre occurrences non homologues, ce qui pourrait être le signe d'un phénomène de convergence évolutive. De plus, nous observons que certaines parties du contexte 3D semblent mieux conservées que d'autres entre occurrences non homologues.Dans un troisième temps, nous étudions la capacité de prédiction du contexte topologique commun à des occurrences de motif A-minor, partageant des contextes 3D similaires, ainsi que la capacité de prédiction d'un signal de séquence sur ces mêmes occurrences. Pour cela, nous étudions la fréquence d'apparition de cette topologie et de ces séquences dans des structures d'ARN en l'absence de motifs A-minor. Nous en concluons que la topologie et la séquence associées représentent un bon signal pour la majorité des classes d'occurrences homologues étudiées.
102774_GIANFROTTA_2022_archivage.pdf (16.98 Mo) Télécharger le fichier
Origin : Version validated by the jury (STAR)
Dates and versions
tel-03867018 , version 1 (23-11-2022)
Identifiers
  • HAL Id : tel-03867018 , version 1
Cite
Coline Gianfrotta. Modélisation, analyse et classification de motifs structuraux d'ARN à partir de leur contexte, par des méthodes d'algorithmique de graphes. Bio-informatique [q-bio.QM]. Université Paris-Saclay, 2022. Français. ⟨NNT : 2022UPASG056⟩. ⟨tel-03867018⟩
134 View
46 Download
Share
