Energy Transport and Conversion Within Earth's Supercritical Bow Shock: The Role of Intense Lower‐Hybrid Whistler Waves - Département de physique Access content directly
Journal Articles Journal of Geophysical Research Space Physics Year : 2024
Detailed analysis of a high Mach number quasiperpendicular Earth bow shock crossing by the Magnetospheric Multiscale (MMS) spacecraft fleet reveal that lower‐hybrid (LH) whistler waves generated in the shock foot region transport energy predominately along the shock surface and slightly toward the shock ramp in the shock normal incidence frame, where wave energy accumulates and is dissipated into the plasma. This suggests the LH whistlers play an integral role in energy reconfiguration at high Mach number collisionless shocks with ramifications to plasma heating. The multipoint observations are used to quantify the wave characteristic parameters (via interferometry), Poynting fluxes, and energy conversion rates D, and to assess their scale dependencies and spatial and temporal properties. The whistler associated energy transport and conversion are found to depend on scale and location within the layer. High‐frequency electrostatic waves yield largest values of D. However, the dominant net energy exchange contribution is from the LH whistlers. In the foot spatially temporally coherent net energy exchange from the plasma to whistlers is observed, whereas deeper in the ramp net wave energy dissipation to the plasma is observed exhibiting significant space‐time variability. These results are consistent with the modified two stream instability driven by the relative drift between reflected ions and electrons as the mechanism for wave growth in the foot. Owing to strong electron heating, whistler energy dissipation in the ramp is attributed to Landau damping, which out‐competes the destabilizing effect of the reflected ion and electron drift.
JGR Space Physics - 2024 - Hull - Energy Transport and Conversion Within Earth s Supercritical Bow Shock The Role of.pdf (10.17 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
licence : CC BY NC ND - Attribution - NonCommercial - NoDerivatives
Dates and versions
insu-04564827 , version 1 (30-04-2024)
Identifiers
Cite
Arthur J Hull, Laurent Muschietti, Oleksiy V Agapitov, Christopher C Chaston, Olivier Le Contel, et al.. Energy Transport and Conversion Within Earth's Supercritical Bow Shock: The Role of Intense Lower‐Hybrid Whistler Waves. Journal of Geophysical Research Space Physics, 2024, 129 (5), pp.e2023JA031630. ⟨10.1029/2023JA031630⟩. ⟨insu-04564827⟩
0 View
0 Download
Share
