Brainomics: A management system for exploring and merging heterogeneous brain mapping data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an open source solution to manage brain imaging datasets and associated meta data. This framework is a powerful querying and reporting tool, customized for the needs of the emerging imaging-genetics field. A demonstration website and more details are available at http:/brainomics.cea.fr.
hbm2013_ter.pdf (960.21 Ko) Télécharger le fichier
cea-00904768 , version 1 (15-11-2013)
  • HAL Id : cea-00904768 , version 1
Vincent Michel, Yannick Schwartz, Philippe Pinel, Olivier Cayrol, Antonio Moreno, et al.. Brainomics: A management system for exploring and merging heterogeneous brain mapping data. OHBM 2013 19th Annual Meeting of the Organization for Human Brain Mapping, Jun 2013, Seattle, United States. ⟨cea-00904768⟩
1064 Consultations
199 Téléchargements
