Computing Integer Powers in Floating-Point Arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
We introduce two algorithms for accurately evaluating powers to a positive integer in floating-point arithmetic, assuming a fused multiply-add (fma) instruction is available. We show that our log-time algorithm always produce faithfully-rounded results, discuss the possibility of getting correctly rounded results, and show that results correctly rounded in double precision can be obtained if extended-precision is available with the possibility to round into double precision (with a single rounding).
RRpower.pdf (150.34 Ko) Télécharger le fichier
ensl-00150406 , version 1 (30-05-2007)
Peter Kornerup, Vincent Lefèvre, Jean-Michel Muller. Computing Integer Powers in Floating-Point Arithmetic. 2007. ⟨ensl-00150406⟩
181 Consultations
202 Téléchargements
