Computing Correctly Rounded Integer Powers in Floating-Point Arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
We introduce several algorithms for accurately evaluating powers to a positive integer in floating-point arithmetic, assuming a fused multiply-add (fma) instruction is available. We aim at always obtaining correctly-rounded results in round-to-nearest mode, that is, our algorithms return the floating-point number that is nearest the exact value.
Autre [cs.OH]
power-journalV9.pdf (202.69 Ko) Télécharger le fichier
ensl-00278430 , version 1 (13-05-2008)
  • HAL Id : ensl-00278430 , version 1
Jean-Michel Muller, Peter Kornerup, Christoph Lauter, Vincent Lefèvre, Nicolas Louvet. Computing Correctly Rounded Integer Powers in Floating-Point Arithmetic. 2008. ⟨ensl-00278430⟩
290 Consultations
338 Téléchargements
