Fixed-Point Trigonometric Functions on FPGAs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Three approaches for computing sines and cosines on FPGAs are studied in this paper, with a focus of high-throughput pipelined architecture, and state-of-the-art implementation techniques. The first approach is the classical CORDIC iteration, for which we suggest a reduced iteration technique and fine optimizations in datapath width and latency. The second is an ad-hoc architecture specifically designed around trigonometric identities. The third uses a generic table- and DSP-based polynomial approximator. These three architectures are implemented and compared in the FloPoCo framework.
2013-SinCos-RR.pdf (264.09 Ko) Télécharger le fichier
ensl-00802777 , version 1 (20-03-2013)
  • HAL Id : ensl-00802777 , version 1
Florent de Dinechin, Matei Istoan, Guillaume Sergent. Fixed-Point Trigonometric Functions on FPGAs. Fourth International Symposium on Highly-Efficient Accelerators and Reconfigurable Technologies, Jun 2013, Edimburgh, United Kingdom. pp.1-6. ⟨ensl-00802777⟩
270 Consultations
4541 Téléchargements
