Dynamic Load Balancing for Adaptive Mesh Ocean Circulation Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Engineering Simulations Année : 2000
This paper reports the parallel implementation of adaptive mesh refinement within finite difference ocean circulation models. The implementation is based on the model of Malleable Tasks with inefficiency factor which allows a simple expression of the different levels of parallelism with a good efficiency. Our goal within this work was to validate this approach on an actual application. For that, we have implemented a load-balancing strategy based on the well-known level-by-level mapping. Preliminary experiments are discussed at the end of the paper.
bdmt00.pdf (292.58 Ko) Télécharger le fichier
hal-00003946 , version 1 (20-01-2005)
  • HAL Id : hal-00003946 , version 1
Eric Blayo, Laurent Debreu, Grégory Mounié, Denis Trystram. Dynamic Load Balancing for Adaptive Mesh Ocean Circulation Model. Engineering Simulations, 2000, 22 (2), pp.8-24. ⟨hal-00003946⟩
163 Consultations
202 Téléchargements
