Article Dans Une Revue Journal of Multivariate Analysis Année : 2008
Frontier estimation via kernel regression on high power-transformed data
We present a new method for estimating the frontier of a multidimensional sample. The estimator is based on a kernel regression on the power-transformed data. We assume that the exponent of the transformation goes to infinity while the bandwidth of the kernel goes to zero. We give conditions on these two parameters to obtain almost complete convergence and asymptotic normality. The good performance of the estimator is illustrated on some finite sample situations.
girard_jacob2.pdf (238.39 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00077683 , version 1 (31-05-2006)
hal-00077683 , version 2 (09-01-2007)
hal-00077683 , version 3 (10-01-2007)
Stéphane Girard, Pierre Jacob. Frontier estimation via kernel regression on high power-transformed data. Journal of Multivariate Analysis, 2008, 99, pp.403-420. ⟨10.1016/j.jmva.2006.11.006⟩. ⟨hal-00077683v3⟩
327 Consultations
402 Téléchargements
More
