Computing representations for radicals of finitely generated differential ideals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 1999
This paper deals with systems of polynomial differential equations, ordinary or with partial derivatives. The embedding theory is the differential algebra of Ritt and Kolchin. We describe an algorithm, named Rosenfeld-Gröbner, which computes a representation for the radical P of the differential ideal generated by any such system S. The computed representation constitutes a normal simplifier for the equivalence relation modulo P (it permits to test membership in P). It permits also to compute Taylor expansions of solutions of S. The algorithm is implemented within a package in MAPLE V.
blop97.pdf (487.45 Ko) Télécharger le fichier
hal-00139061 , version 1 (29-03-2007)
  • HAL Id : hal-00139061 , version 1
François Boulier, Daniel Lazard, François Ollivier, Michel Petitot. Computing representations for radicals of finitely generated differential ideals. 1999. ⟨hal-00139061⟩
849 Consultations
145 Téléchargements
