A general adaptive multi-resolution approach to ocean modelling: experiments in a primitive equation model of the North Atlantic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2005
Laurent Debreu
Eric Blayo
Following the work of [BD99], the present paper presents a general approach to adaptive mesh refinement for ocean models. The numerical procedure is briefly described, as well as a software package which easily allows for the actual implementation of multiresolution within any existing finite difference model. The effectiveness of this approach for ocean modelling, even at a basin-scale, is illustrated in the context of a primitive equation numerical model of the north Atlantic. Several experiments are presented, which demonstrate the potentialities of mesh refinement and emphasize the role of the refinement criterion.
hal-00184033 , version 1 (30-10-2007)
Laurent Debreu, Eric Blayo, Bernard Barnier. A general adaptive multi-resolution approach to ocean modelling: experiments in a primitive equation model of the North Atlantic. Tomasz Plewa; Timur Linde; V. Gregory Weirs. Adaptive Mesh Refinement - Theory and Applications, 41, Springer, pp.303-313, 2005, 9783540211471. ⟨10.1007/3-540-27039-6_21⟩. ⟨hal-00184033⟩
86 Consultations
0 Téléchargements
