An elasto-visco-plastic model for immortal foams or emulsions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Physical Journal E: Soft matter and biological physics Année : 2008
A variety of complex fluids consist in soft, round objects (foams, emulsions, assemblies of copolymer micelles or of multilamellar vesicles --- also known as onions). Their dense packing induces a slight deviation from their prefered circular or spherical shape. As a frustrated assembly of interacting bodies, such a material evolves from one conformation to another through a succession of discrete, topological events driven by finite external forces. As a result, the material exhibits a finite yield threshold. The individual objects usually evolve spontaneously (colloidal diffusion, object coalescence, molecular diffusion), and the material properties under low or vanishing stress may alter with time, a phenomenon known as aging. We neglect such effects to address the simpler behaviour of (uncommon) immortal fluids: we construct a minimal, fully tensorial, rheological model, equivalent to the (scalar) Bingham model. Importantly, the model consistently describes the ability of such soft materials to deform substantially in the elastic regime (be it compressible or not) before they undergo (incompressible) plastic creep --- or viscous flow under even higher stresses.
Foam_plasticity_Benito_et_al.pdf (625.73 Ko) Télécharger le fichier
hal-00184793 , version 1 (01-11-2007)
Sylvain Bénito, Charles-Henri Bruneau, Thierry Colin, Cyprien Gay, François Molino. An elasto-visco-plastic model for immortal foams or emulsions. European Physical Journal E: Soft matter and biological physics, 2008, 25, pp.225-251. ⟨10.1140/epje/i2007-10284-2⟩. ⟨hal-00184793⟩
359 Consultations
275 Téléchargements
