Oscillations in the expression of a self-repressed gene induced by a slow transcriptional dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2009
We revisit the dynamics of a gene repressed by its own protein in the case where the transcription rate does not adapt instantaneously to protein concentration but is a dynamical variable. We derive analytical criteria for the appearance of sustained oscillations and find that they require degradation mechanisms much less nonlinear than for infinitely fast regulation. Deterministic predictions are also compared with stochastic simulations of this minimal genetic oscillator.
degradatorV3.pdf (766.65 Ko) Télécharger le fichier
hal-00268097 , version 1 (31-03-2008)
hal-00268097 , version 2 (12-01-2009)
Pierre-Emmanuel Morant, Quentin Thommen, François Lemaire, Constant Vandermoëre, Benjamin Parent, et al.. Oscillations in the expression of a self-repressed gene induced by a slow transcriptional dynamics. Physical Review Letters, 2009, 102 (6), pp.068104. ⟨10.1103/PhysRevLett.102.068104⟩. ⟨hal-00268097v2⟩
233 Consultations
201 Téléchargements
