Differential algebra and system modeling in cellular biology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Computer Science Année : 2008
Among all the modeling approaches dedicated to cellular biology, differential algebra is particularly related to the well-established one based on nonlinear differential equations. In this paper, it is shown that differential algebra makes both simple and algorithmic one of the model reduction methods, the quasi-steady state approximation theory, in the particular setting of generalized chemical reactions systems. This recent breakthrough may suggest some evolution of modeling techniques based on nonlinear differential equations, by incorporating the reduction hypotheses in the models. Potential improvements of parameters fitting methods are discussed too.
BL-AB08.pdf (190.2 Ko) Télécharger le fichier
hal-00274689 , version 1 (21-04-2008)
  • HAL Id : hal-00274689 , version 1
François Boulier, François Lemaire. Differential algebra and system modeling in cellular biology. AB 2008, 2008, Hagenberg, Austria. pp.22-39. ⟨hal-00274689⟩
205 Consultations
178 Téléchargements
