Retrieving ocean surface current by 4-D variational assimilation of sea surface temperature images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Remote Sensing of Environment Année : 2008
In this article we propose a new method to estimate ocean mesoscale structures of the surface current velocity by processing sea surface satellite images. Assuming that the intensity level can be described by a transport-diffusion equation, the proposed approach is based on variational assimilation of image observations within a simple transport-diffusion model. This approach permits to retrieve the current velocity field from a sequence of satellite images. Results of processing synthetic data and real NOAA-AVHRR satellite images are presented and commented.
Océanographie
hal-00283896 , version 1 (31-05-2008)
Gennady K. Korotaev, Etienne Huot, François-Xavier Le Dimet, Isabelle Herlin, S.V. Stanichny, et al.. Retrieving ocean surface current by 4-D variational assimilation of sea surface temperature images. Remote Sensing of Environment, 2008, 112 (4), pp.1464-1475. ⟨10.1016/j.rse.2007.04.020⟩. ⟨hal-00283896⟩
431 Consultations
0 Téléchargements
