Efficient Region-Based Memory Management for Resource-limited Real-Time Embedded Systems. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a simple and efficient static analysis algorithm, combined with a region allocation policy for real-time embedded Java applications. The goal of this work is to provide a static analysis mechanism efficient enough to be integrated in an assisted-development environment, and to implement region-based memory management primitives suited for resource-limited platforms such as smart cards.
06-Salagnac-ICOOOLPS.pdf (169.96 Ko) Télécharger le fichier
hal-00309688 , version 1 (07-08-2008)
  • HAL Id : hal-00309688 , version 1
Guillaume Salagnac, Chaker Nakhli, Christophe Rippert, Sergio Yovine. Efficient Region-Based Memory Management for Resource-limited Real-Time Embedded Systems.. Workshop on Implementation, Compilation, Optimization of Object-Oriented Languages, Programs and Systems, in association with the 20th ACM ECOOP conference, Jul 2006, Nantes, France. ⟨hal-00309688⟩
205 Consultations
907 Téléchargements
