Model-based Adaptation of Behavioural Mismatching Components - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Software Engineering Année : 2008
Component-Based Software Engineering focuses on the reuse of existing software components. In practice, most components cannot be integrated directly into an application-to-be, because they are incompatible. Software Adaptation aims at generating, as automatically as possible, adaptors to compensate mismatch between component interfaces, and is therefore a promising solution for the development of a real market of components promoting software reuse. In this article, we present our approach for software adaptation which relies on an abstract notation based on synchronous vectors and transition systems for governing adaptation rules. Our proposal is supported by dedicated algorithms that generate automatically adaptor protocols. These algorithms have been implemented in a tool, called Adaptor, that can be used through a user-friendly graphical interface.
RR-CPS08.pdf (1.47 Mo) Télécharger le fichier
hal-00340122 , version 1 (04-10-2016)
Carlos Canal, Pascal Poizat, Gwen Salaün. Model-based Adaptation of Behavioural Mismatching Components. IEEE Transactions on Software Engineering, 2008, 34 (4), pp.546--563. ⟨10.1109/TSE.2008.31⟩. ⟨hal-00340122⟩
262 Consultations
262 Téléchargements
