An Access Control Model for Tree Data Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Alban Gabillon
Jean Jacques Bascou
Emmanuel Bruno
Trees are very often used to structure data. For instance, file systems are structured into trees and XML documents can be represented by trees. There are literally as many access control schemes as there are tree data structures. Consequently, an access control model which has been defined for a particular kind of tree cannot be easily adapted to another kind of tree. In this paper, we propose an access control model for generic tree data structures. This model can then be applied to any specific typed tree data structure. \textcopyright Springer-Verlag Berlin Heidelberg 2002.
isc02gabillon.pdf (429.69 Ko) Télécharger le fichier
hal-01912344 , version 1 (20-01-2020)
Alban Gabillon, Manuel Munier, Jean Jacques Bascou, Laurent Gallon, Emmanuel Bruno. An Access Control Model for Tree Data Structures. Information Security, 5th International Conference, ISC 2002 Sao Paulo, Brazil, September 30 - October 2, 2002, Proceedings, Sep 2002, Sao Paulo, Brazil. pp.117-135, ⟨10.1007/3-540-45811-5_9⟩. ⟨hal-01912344⟩
115 Consultations
687 Téléchargements
