Sublinear Fully Distributed Partition with Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory of Computing Systems Année : 2010
We present new efficient deterministic and randomized distributed algorithms for decomposing a graph with $n$ nodes into a disjoint set of connected clusters with radius at most $k-1$ and having $O(n^{1+1/k})$ intercluster edges. We show how to implement our algorithms in the distributed $\mathcal{CONGEST}$ model of computation, i.e., limited message size, which improves the time complexity of previous algorithms~\cite{MS00,Awe85,Peleg00b} from $O(n)$ to $O(n^{1-1/k})$. We apply our algorithms for constructing low stretch graph spanners and network synchronizers in sublinear deterministic time in the $\mathcal{CONGEST}$ model.
Autre [cs.OH]
hal-00351045 , version 1 (08-01-2009)
Bilel Derbel, Mohamed Mosbah, Akka Zemmari. Sublinear Fully Distributed Partition with Applications. Theory of Computing Systems, 2010, 47 (3), pp.368-404. ⟨10.1007/s00224-009-9190-x⟩. ⟨hal-00351045⟩
152 Consultations
0 Téléchargements
