s'authentifier
version française rss feed
hal-00360275, version 1
NewMadeleine: An Efficient Support for High-Performance Networks in MPICH2
Guillaume Mercier () 123, François Trahay 12, Darius Buntinas 4, Elisabeth Brunet 12
International Parallel and Distributed Processing Symposium (2009) 35
Résumé : This paper describes how the NewMadeleine communication library has been integrated within the MPICH2 MPI implementation and the benefits brought. NewMadeleine is integrated as a Nemesis network module but the upper layers and in particular the CH3 layer has been modified. By doing so, we allow NewMadeleine to fully deliver its performance to an MPI application. NewMadeleine features sophisticated strategies for sending messages and natively supports multirail network configurations, even heterogeneous ones. It also uses a software element called PIOMan that uses multithreading in order to enhance reactivity and create more efficient progress engines. We show various results that prove that NewMadeleine is indeed well suited as a low-level communication library for building MPI implementations.
  • Collaboration : Grid'5000
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • Mots-clés : SMP Systems – Shared Memory – Data Transfers – Performance Evaluation
  • hal-00360275, version 1
  • oai:hal.archives-ouvertes.fr:hal-00360275
  • Contributeur :
  • Soumis le : Mardi 10 Février 2009, 18:09:23
  • Dernière modification le : Lundi 23 Avril 2012, 16:26:44
tous les articles de la base du CCSd...
