Asymptotics Methods to Compute Electromagnetic Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Laurent Krähenbühl
Laurent Nicolas
We provide a rigorous asymptotic method to compute the electromagnetic _elds in domains with thin layer. With this method the in_uency of the membrane on the inner _eld is replaced by an approximated boundary condition, while in the thin layer, the approximated _eld is explicitely known. We give error estimates, which validate our asymptotic.
Compumag2007_Poignard.pdf (206.34 Ko) Télécharger le fichier
hal-00360339 , version 1 (11-02-2009)
  • HAL Id : hal-00360339 , version 1
Clair Poignard, Patrick Dular, Laurent Krähenbühl, Laurent Nicolas, Michelle Schatzman. Asymptotics Methods to Compute Electromagnetic Fields. Compumag 2007, Jun 2007, Aachen, Germany. pp.979. ⟨hal-00360339⟩
277 Consultations
425 Téléchargements
