Applying Model Driven Engineering Techniques and Tools to the Planets Game Learning Scenario - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Interactive Media in Education Année : 2008
CPM (Cooperative Problem-Based learning Metamodel) is a visual language for the instructional design of Problem-Based Learning (PBL) situations. This language is a UML profile implemented on top of the Objecteering UML Case tool. In this article, we first present the way we used CPM language to bring about the pedagogical transposition of the planets game learning scenario. Then, we propose some related works conducted to improve CPM usability: on the one hand, we outline a MOF solution and an Eclipse GMF solution instead of the UML profile approach. On the other hand, we propose some explanations about transforming CPM models into LMS compliant data, and tool functionality.
jime-2008-23.pdf (1.24 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00372414 , version 1 (01-04-2009)
  • HAL Id : hal-00372414 , version 1
Thierry Nodenot, Pierre-André Caron, Xavier Le Pallec, Pierre Laforcade. Applying Model Driven Engineering Techniques and Tools to the Planets Game Learning Scenario. Journal of Interactive Media in Education, 2008, http://jime.open.ac.uk/2008/23/. ⟨hal-00372414⟩
463 Consultations
504 Téléchargements
