Comparison of Two Self-organization and Hierarchical Routing Protocols for Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this article, we compare two self-organization and hierarchical routing protocols for ad hoc networks. These two protocols apply the reverse approach from the classical one, since they use a reactive routing protocol inside the clusters and a proactive routing protocol between the clusters. We compare them regarding the cluster organization they provide and the routing that is then performed over it. This study gives an idea of the impact of the use of recursiveness and of the partition of the DHT on self-organization and hierarchical routing in ad hoc networks.
MSN06_149.pdf (157.91 Ko) Télécharger le fichier
hal-00383993 , version 1 (14-05-2009)
  • HAL Id : hal-00383993 , version 1
Betânia Steffen Abdallah Goncalves, Nathalie Mitton, Isabelle Guérin Lassous. Comparison of Two Self-organization and Hierarchical Routing Protocols for Ad Hoc Networks. Mobile Ad-hoc and Sensor Networks, Second International Conference, MSN 2006, Dec 2006, Hong Kong, China. pp.25-37. ⟨hal-00383993⟩
151 Consultations
221 Téléchargements
