Cost over Progress Based Energy Efficient Routing over Virtual Coordinates in Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We propose an energy efficient routing protocol, VCost, for sensor networks. We assume that nodes are unaware of their geographic location thus, VCost assigns virtual coordinates to nodes as follows. Based on the node hop count distances from a set of landmarks, our method computes a distance metric to obtain the node's virtual coordinates. VCost, then uses these coordinates to route packets from node u to node v, in its neighborhood, such that the ratio of the cost to send a message to v to the progress in the routing task towards the destination is minimized. Compared to existing algorithms that use virtual locations, our simulation shows that VCost improves significantly energy consumption and preserves the small percentage of successful routings.
main_final.pdf (415.38 Ko) Télécharger le fichier
hal-00383999 , version 1 (14-05-2009)
  • HAL Id : hal-00383999 , version 1
Essia Hamouda Elhafsi, Nathalie Mitton, David Simplot-Ryl. Cost over Progress Based Energy Efficient Routing over Virtual Coordinates in Wireless Sensor Networks. IEEE International Workshop "From Theory To Practice in Wireless Sensor Networks" (t2pWSN), Jun 2007, Helsinki, Finland. pp.1-6. ⟨hal-00383999⟩
251 Consultations
156 Téléchargements
