Ascending runs in dependent uniformly distributed random variables: Application to wireless networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Methodology and Computing in Applied Probability Année : 2010
We analyze in this paper the longest increasing contiguous sequence or maximal ascending run of random variables with common uniform distribution but not independent. Their dependence is characterized by the fact that two successive random variables cannot take the same value. Using a Markov chain approach, we study the distribution of the maximal ascending run and we develop an algorithm to compute it. This problem comes from the analysis of several self-organizing protocols designed for large-scale wireless sensor networks, and we show how our results applies to this domain.
pub_inria.pdf (231.98 Ko) Télécharger le fichier
hal-00384027 , version 1 (14-05-2009)
Nathalie Mitton, Katy Paroux, Bruno Sericola, Sébastien Tixeuil. Ascending runs in dependent uniformly distributed random variables: Application to wireless networks. Methodology and Computing in Applied Probability, 2010, 12 (1), pp.51-62. ⟨10.1007/s11009-008-9088-0⟩. ⟨hal-00384027⟩
481 Consultations
111 Téléchargements
