Two-way embedding algorithms: a review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ocean Dynamics Année : 2008
Local mesh refinement features have now been added to a number of numerical ocean models. In its crudest form, a high-resolution grid is embedded (or nested) in a coarse-resolution grid, which covers the entire domain, and the two grids interact. The aim of this paper is to review existing two-way grid embedding algorithms. The basic algorithms and specificities related to ocean modelling are first described. Then, we address several important issues: conservation properties, design of interpolation/restriction operators, and noise control techniques.
Debreu.pdf (608.13 Ko) Télécharger le fichier
hal-00387449 , version 1 (17-01-2024)
Laurent Debreu, Eric Blayo. Two-way embedding algorithms: a review. Ocean Dynamics, 2008, 58 (5-6), pp.415-428. ⟨10.1007/s10236-008-0150-9⟩. ⟨hal-00387449⟩
215 Consultations
17 Téléchargements
