A mathematical analysis of the resonance of the finite thin slots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Numerical Mathematics Année : 2006
In this article we are interested in the asymptotic behaviour of the solution of a wave propagation problem in a domain including a thin slot. Some rate of convergences are obtained and illustrated by numerical results.
ClaDurJolTor.pdf (391.38 Ko) Télécharger le fichier
hal-00404068 , version 1 (15-07-2009)
  • HAL Id : hal-00404068 , version 1
Marianne Clausel, Marc Duruflé, Patrick Joly, Sébastien Tordeux. A mathematical analysis of the resonance of the finite thin slots. Applied Numerical Mathematics, 2006, 56 (10-11), pp.1432-1449. ⟨hal-00404068⟩
263 Consultations
213 Téléchargements
