Spurious diapycnal mixing in terrain-following coordinate models: The problem and a solution
In this paper, we identify a crucial numerical problem in sigma coordinate models, leading to unacceptable spurious diapycnal mixing. This error is a by-product of recent advances in numerical methods, namely the implementation of high-order diffusive advection schemes. In the case of ROMS, spurious mixing is produced by its third-order upwind advection scheme, but our analysis suggests that all diffusive advection schemes would behave similarly in all sigma models. We show that the common idea that spurious mixing decreases with resolution is generally false. In a coarse-resolution regime, spurious mixing increases as resolution is refined, and may reach its peak value when eddy-driven lateral mixing becomes explicitly resolved. At finer resolution, diffusivities are expected to decrease but with values that only become acceptable at resolutions finer than the kilometer. The solution to this problem requires a specifically designed advection scheme. We propose and validate the RSUP3 scheme, where diffusion is split from advection and is represented by a rotated biharmonic diffusion scheme with flow-dependent hyperdiffusivity satisfying the Peclet constraint. The rotated diffusion operator is designed for numerical stability, which includes improvements of linear stability limits and a clipping method adapted to the sigma-coordinate. Realistic model experiments in a southwest Pacific configuration show that RSUP3 is able to preserve low dispersion and diffusion capabilities of the original third-order upwind scheme, while preserving water mass characteristics. There are residual errors from the rotated diffusion operator, but they remain acceptable. The use of a constant diffusivity rather than the Peclet hyperdiffusivity tends to increase these residual errors which become unacceptable with Laplacian diffusion. Finally, we have left some options open concerning the use of time filters as an alternative to spatial diffusion. A temporal discretization approach to the present problem (including implicit discretization) will be reported in a following paper. (C) 2008 Elsevier Ltd. All rights reserved.
