Influence of a rough thin layer on the potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Ronan Perrussel
Connectez-vous pour contacter l'auteur
Clair Poignard
In this paper, we study the behavior of the steadystate voltage potentials in a material composed by an interior medium surrounded by a rough thin layer and embedded in an ambient bounded medium. The roughness of the layer is supposed to be "–periodic, " being the small thickness of the layer. We present and validate numerically the rigorous approximate transmissions proved by Ciuperca et al. in [http://hal.inria.fr/inria-00356124/fr/]. This paper extends previous works in which the layer had a constant thickness
Compumag2008_Perrussel4.pdf (117.88 Ko) Télécharger le fichier
hal-00412388 , version 1 (01-09-2009)
  • HAL Id : hal-00412388 , version 1
Ionel Sorin Ciuperca, Ronan Perrussel, Clair Poignard. Influence of a rough thin layer on the potential. Compumag 2009, Nov 2009, Florianópolis, Brazil. à paraître. ⟨hal-00412388⟩
910 Consultations
84 Téléchargements
