Submodular Partition Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics Année : 2009
Adapting the method introduced in Graph Minors X, we propose a new proof of the duality between the bramble number of a graph and its tree-width. Our approach is based on a new definition of submodularity on partition functions which naturally extends the usual one on set functions. The proof does not rely on Menger's theorem, and thus generalises the original one. It thus provides a dual for matroid tree-width. One can also derive all known dual notions of other classical width-parameters from it.
partsub.pdf (172.75 Ko) Télécharger le fichier
lirmm-00432698 , version 1 (31-08-2010)
Omid Amini, Frédéric Mazoit, Nicolas Nisse, Stéphan Thomassé. Submodular Partition Functions. Discrete Mathematics, 2009, 309, pp.6000-6008. ⟨10.1016/j.disc.2009.04.033⟩. ⟨lirmm-00432698⟩
415 Consultations
329 Téléchargements
