VARNA: Interactive drawing and editing of the RNA secondary structure. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2009
DESCRIPTION: VARNA is a tool for the automated drawing, visualization and annotation of the secondary structure of RNA, designed as a companion software for web servers and databases. FEATURES: VARNA implements four drawing algorithms, supports input/output using the classic formats dbn, ct, bpseq and RNAML and exports the drawing as five picture formats, either pixel-based (JPEG, PNG) or vector-based (SVG, EPS and XFIG). It also allows manual modification and structural annotation of the resulting drawing using either an interactive point and click approach, within a web server or through command-line arguments. AVAILABILITY: VARNA is a free software, released under the terms of the GPLv3.0 license and available at http://varna.lri.fr. SUPPLEMENTARY INFORMATION: Supplementary data are available at Bioinformatics online.
VARNA-Bioinfo-R2-NoHighlight.pdf (132.28 Ko) Télécharger le fichier
hal-00432548 , version 1 (16-11-2009)
Kévin Darty, Alain Denise, Yann Ponty. VARNA: Interactive drawing and editing of the RNA secondary structure.. Bioinformatics, 2009, 25 (15), pp.1974-5. ⟨10.1093/bioinformatics/btp250⟩. ⟨hal-00432548⟩
758 Consultations
739 Téléchargements
