Special issue on implicit computational complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques ACM Transactions on Computational Logic Année : 2006
This special issue of ACM Transactions on Computational Logic is devoted to Implicit Computational Complexity, following the Workshop on Implicit Computational Complexity held in Marseilles in February 2006 as part of the special thematic session on Geometry of Computation (GEOCAL'06) at the Centre International de Rencontres Mathématiques. The articles selected had been submitted responding to a public call-for-papers after the workshop and have undergone the TOCL standard refereeing process.
IntroTOCL.pdf (37.53 Ko) Télécharger le fichier
hal-00434330 , version 1 (22-11-2009)
Patrick Baillot, Jean-Yves Marion, Simona Ronchi Della Rocca. Special issue on implicit computational complexity. ACM Trans. Comput. Log. (10)4. Workshop on Implicit Computational Complexity - Geometry of Computation (GEOCAL'06), Feb 2006, Marseille, France. 10 (4), 2 p., 2009, ⟨10.1145/1555746.1555747⟩. ⟨hal-00434330⟩
191 Consultations
70 Téléchargements
