Malliavin calculus for fractional delay equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Theoretical Probability Année : 2012
Jorge A. Leon
  • Fonction : Auteur
  • PersonId : 836257
Samy Tindel
  • Fonction : Auteur
  • PersonId : 832698
In this paper we study the existence of a unique solution to a general class of Young delay differential equations driven by a Hölder continuous function with parameter greater that 1/2 via the Young integration setting. Then some estimates of the solution are obtained, which allow to show that the solution of a delay differential equation driven by a fractional Brownian motion (fBm) with Hurst parameter H>1/2 has a smooth density. To this purpose, we use Malliavin calculus based on the Frechet differentiability in the directions of the reproducing kernel Hilbert space associated with fBm.
mallia-delay14.pdf (375.04 Ko) Télécharger le fichier
hal-00440655 , version 1 (11-12-2009)
Jorge A. Leon, Samy Tindel. Malliavin calculus for fractional delay equations. Journal of Theoretical Probability, 2012, 25 (3), pp.854-889. ⟨10.1007/s10959-011-0349-4⟩. ⟨hal-00440655⟩
226 Consultations
163 Téléchargements
