A Milstein-type scheme without Levy area terms for SDEs driven by fractional Brownian motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques Année : 2012
Aurélien Deya
  • Fonction : Auteur
  • PersonId : 853648
Samy Tindel
  • Fonction : Auteur
  • PersonId : 832698
In this article, we study the numerical approximation of stochastic differential equations driven by a multidimensional fractional Brownian motion (fBm) with Hurst parameter greater than 1/3. We introduce an implementable scheme for these equations, which is based on a second order Taylor expansion, where the usual Levy area terms are replaced by products of increments of the driving fBm. The convergence of our scheme is shown by means of a combination of rough paths techniques and error bounds for the discretisation of the Levy area terms.
approx-scheme-10.pdf (431.27 Ko) Télécharger le fichier
hal-00448685 , version 1 (19-01-2010)
Aurélien Deya, Andreas Neuenkirch, Samy Tindel. A Milstein-type scheme without Levy area terms for SDEs driven by fractional Brownian motion. Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques, 2012, 48 (2), pp.518-550. ⟨10.1214/10-AIHP392⟩. ⟨hal-00448685⟩
158 Consultations
205 Téléchargements
