Grammar Error Detection with Best Approximated Parse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we propose that grammar error detection be disambiguated in generating the connected parse(s) of optimal merit for the full input utterance, in overcoming the cheapest error. The detected error( s) are described as violated grammatical constraints in a framework for Model- Theoretic Syntax (MTS). We present a parsing algorithm for MTS, which only relies on a grammar of well-formedness, in that the process does not require any extragrammatical resources, additional rules for constraint relaxation or error handling, or any recovery process.
prost-iwpt09-short.pdf (85.05 Ko) Télécharger le fichier
hal-00468007 , version 1 (29-03-2010)
  • HAL Id : hal-00468007 , version 1
Jean-Philippe Prost. Grammar Error Detection with Best Approximated Parse. 11th International Conference on Parsing Technology (IWPT'09), Oct 2009, Paris, France. pp.172--175. ⟨hal-00468007⟩
128 Consultations
115 Téléchargements
