Modeling the early ionization of dielectrics by ultrashort laser pulses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2010
In this paper, we present a model for propagation of intense and ultrashort laser pulses ionizing dielectrics. We consider early ion- ization so that this process is sufficiently weak to avoid requiring a complete description of the ionization process (e.g. the use of ki- netic equations which are very expensive from a computational point of view). As the intensity of the field is small, one photon ioniza- tion is neglected. Ionization may only occur through multi-photonic and collisional ionization. The conduction band is discretized and multiple-rate equations are written for electron densities. The wave- field evolves through Maxwell equations.
ion.pdf (515.65 Ko) Télécharger le fichier
hal-00489482 , version 1 (04-06-2010)
Antoine Bourgeade, Candice Mézel, Olivier Saut. Modeling the early ionization of dielectrics by ultrashort laser pulses. Journal of Scientific Computing, 2010, 44, pp.170-190. ⟨10.1007/s10915-010-9375-0⟩. ⟨hal-00489482⟩
266 Consultations
356 Téléchargements
