Analyse syntaxique du français : des constituants aux dépendances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper describes a technique for both constituent and dependency parsing. Parsing proceeds by adding functional labels to the output of a constituent parser trained on the French Treebank in order to further extract typed dependencies. On the one hand we specify on formal and linguistic grounds the nature of the dependencies to output as well as the conversion algorithm from the French Treebank to this dependency representation. On the other hand, we describe a class of algorithms that allows to perform the automatic labeling of the functions from the output of a constituent based parser. We specifically focus on discriminative learning methods for functional labelling.
taln2009.pdf (115.1 Ko) Télécharger le fichier
hal-00495287 , version 1 (07-09-2010)
  • HAL Id : hal-00495287 , version 1
Marie Candito, Benoît Crabbé, Pascal Denis, François Guérin. Analyse syntaxique du français : des constituants aux dépendances. 16e Conférence sur le Traitement Automatique des Langues Naturelles - TALN 2009, Jun 2009, Senlis, France. ⟨hal-00495287⟩
399 Consultations
1377 Téléchargements
