Strong phase-space semiclassical asymptotics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2011
Wigner and Husimi transforms have long been used for the phase- space reformulation of SchrÄodinger-type equations, and the study of the corresponding semiclassical limits. Most of the existing results provide approximations in appropriate weak topologies. In this work we are con- cerned with semiclassical limits in the strong topology, i.e. approxima- tion of Wigner functions by solutions of the Liouville equation in L2 and Sobolev norms. The results obtained improve the state of the art, and highlight the role of potential regularity, especially through the regularity of the Wigner equation. It must be mentioned that the strong conver- gence can be shown up to logarithmic time-scales, which is well known to be, in general, the limit of validity of semiclassical asymptotics.
note14.pdf (412.94 Ko) Télécharger le fichier
hal-00496375 , version 1 (30-06-2010)
Thierry Paul, Agissilaos Athanassoulis. Strong phase-space semiclassical asymptotics. SIAM Journal on Mathematical Analysis, 2011, 43 (5), pp.2116-2149. ⟨10.1137/10078712X⟩. ⟨hal-00496375⟩
304 Consultations
92 Téléchargements
