Influence of a Rough Thin Layer on the Potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2010
In this paper, we study the behavior of the steady-state potentials in a material composed by an interior medium surrounded by a rough thin layer and embedded in an ambient bounded medium. The roughness of the layer is supposed to be $varepsilon^{alpha}$ -periodic, $varepsilon$ being the small thickness of the layer and $alpha$ is a parameter, that describes the roughness of the layer: if $alpha<1$ the layer is weakly rough, while if $alpha>1$, the layer is very rough. Depending on the roughness of the membrane, the approximate transmission conditions are very different. We present and validate numerically the rigorous approximate transmissions proved by Poignard (Math. Meth. Appl. Sci., vol. 32, pp. 435–453, 2009) and Ciuperca (Research reports INRIA RR-6812 and RR-6975). This paper extends previous works of Perrussel and Poignard (IEEE Trans. Magn., vol. 44, pp. 1154–1157, 2008) in which the layer had a constant thickness.
Mots clés
IEEE-T-Mag_46-8_07-2010_2823_Perrussel.pdf (467.98 Ko) Télécharger le fichier
hal-00506120 , version 1 (27-07-2010)
Ionel Sorin Ciuperca, Ronan Perrussel, Clair Poignard. Influence of a Rough Thin Layer on the Potential. IEEE Transactions on Magnetics, 2010, 46 (8), pp.2823 - 2826. ⟨10.1109/TMAG.2010.2044027⟩. ⟨hal-00506120⟩
278 Consultations
167 Téléchargements
