Proving Fixed Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We propose a method to characterize the fixed points described in Tarski's theorem for complete lattices. The method is deductive: the least and greatest fixed points are "proved" in some inference system defined from deduction rules. We also apply the method to two other fixed point theorems, a generalization of Tarski's theorem to chain-complete posets and Bourbaki-Witt's theorem. Finally, we compare the method with the traditional iterative method resorting to ordinals and the original impredicative method used by Tarski.
grall_fics2010.pdf (93.69 Ko) Télécharger le fichier
hal-00507775 , version 1 (31-07-2010)
  • HAL Id : hal-00507775 , version 1
Hervé Grall. Proving Fixed Points. 2010. ⟨hal-00507775⟩
269 Consultations
738 Téléchargements
