Fast recursive grayscale morphology operators: from the algorithm to the pipeline architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Real-Time Image Processing Année : 2013
This paper presents a new algorithm for an efficient computation of morphological operations for gray images and its specific hardware. The method is based on a new recursive morphological decomposition method of 8-convex structuring elements by only causal two-pixel structuring elements (2PSE). Whatever the element size, erosion or/and dilation can then be performed during a unique raster-like image scan involving a fixed reduced analysis neighborhood. The resulting process offers low computation complexity combined with easy description of the element form. The dedicated hardware is generic and fully regular, built from elementary interconnected stages. It has been synthesized into an FPGA and achieves high frequency performances for any shape and size of structuring element.
Fast_recursive_grayscale_morpho_operators_-_JRTIP_2010.pdf (2.5 Mo) Télécharger le fichier
hal-00511013 , version 1 (23-08-2010)
Olivier Déforges, Nicolas Normand, Marie Babel. Fast recursive grayscale morphology operators: from the algorithm to the pipeline architecture. Journal of Real-Time Image Processing, 2013, 5 (3), pp.1-10. ⟨10.1007/s11554-010-0171-8⟩. ⟨hal-00511013⟩
441 Consultations
945 Téléchargements
