Probabilistic cellular automata, invariant measures, and perfect sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Probability Année : 2013
A probabilistic cellular automaton (PCA) can be viewed as a Markov chain. The cells are updated synchronously and independently, according to a distribution depending on a finite neighborhood. We investigate the ergodicity of this Markov chain. A classical cellular automaton is a particular case of PCA. For a one-dimensional cellular automaton, we prove that ergodicity is equivalent to nilpotency, and is therefore undecidable. We then propose an efficient perfect sampling algorithm for the invariant measure of an ergodic PCA. Our algorithm does not assume any monotonicity property of the local rule. It is based on a bounding process which is shown to also be a PCA. Last, we focus on the PCA majority, whose asymptotic behavior is unknown, and perform numerical experiments using the perfect sampling procedure.
hal-00527092 , version 1 (18-10-2010)
Ana Bušić, Jean Mairesse, Irène Marcovici. Probabilistic cellular automata, invariant measures, and perfect sampling. Advances in Applied Probability, 2013, 45 (4), pp.960-980. ⟨10.1239/aap/1386857853⟩. ⟨hal-00527092⟩
239 Consultations
0 Téléchargements
