Pathwise definition of second order SDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2012
Samy Tindel
  • Fonction : Auteur
  • PersonId : 832698
In this article, a class of second order differential equations on [0,1], driven by a general Hölder continuous function and with multiplicative noise, is considered. We first show how to solve this equation in a pathwise manner, thanks to Young integration techniques. We then study the differentiability of the solution with respect to the driving process and consider the case where the equation is driven by a fractional Brownian motion, with two aims in mind: show that the solution we have produced coincides with the one which would be obtained with Malliavin calculus tools, and prove that the law of the solution is absolutely continuous with respect to the Lebesgue measure.
elliptic15.pdf (363.74 Ko) Télécharger le fichier
hal-00531331 , version 1 (02-11-2010)
Lluis Quer-Sardanyons, Samy Tindel. Pathwise definition of second order SDEs. Stochastic Processes and their Applications, 2012, 122 (2), pp.466-497. ⟨10.1016/j.spa.2011.08.014⟩. ⟨hal-00531331⟩
158 Consultations
147 Téléchargements
