An Example of Synchronous Design of Embedded Real-Time Systems based on IMA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We present a study on the design of embedded real-time systems in general, and avionic systems in particular. The synchronous language Signal is used to describe a real world avionic application based on the recent Integrated Modular Avionics concept (IMA). The exposed case study shows how the synchronous technology helps for a reliable and modular design of real-time systems. One major advantage of this technology is the availability of formal tools and techniques for verification and validation, which are important for safety-critical systems such as avionics systems.
rtcsa04.pdf (616.53 Ko) Télécharger le fichier
hal-00541790 , version 1 (01-12-2010)
  • HAL Id : hal-00541790 , version 1
Abdoulaye Gamatié, Thierry Gautier, Paul Le Guernic. An Example of Synchronous Design of Embedded Real-Time Systems based on IMA. 10th International Conference on Real-time and Embedded Computing Systems and Applications (RTCSA 2004), Aug 2004, Gothenburg, Sweden. pp.RTCSA 2004. ⟨hal-00541790⟩
558 Consultations
169 Téléchargements
