Synchronous modeling of avionics applications using the SIGNAL language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper, we discuss a synchronous, component-based approach to the modeling of avionics applications. The specification of the components relies on the avionics standard ARINC 653 and the synchronous language SIGNAL is considered as modeling formalism. The POLYCHRONY tool-set allows for a seamless design process based on the SIGNAL model, which provides possibilities of high level specifications, verification and analysis of the specifications at very early stages of the design, and finally automatic code generation through formal transformations of these specifications. This suits the basic stringent requirements that should be met by any design environment for embedded applications in general, and avionics applications in particular.
RTAS-03.pdf (107.5 Ko) Télécharger le fichier
hal-00541841 , version 1 (01-12-2010)
Abdoulaye Gamatié, Thierry Gautier. Synchronous modeling of avionics applications using the SIGNAL language. 9th IEEE Real-Time and Embedded Technology and Applications Symposium (RTAS 2003), May 2003, Toronto, Canada. pp.144-151, ⟨10.1109/RTTAS.2003.1203046⟩. ⟨hal-00541841⟩
269 Consultations
307 Téléchargements
