Eddy currents and corner singularities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
François Buret
Laurent Krähenbühl
Connectez-vous pour contacter l'auteur
Ronan Perrussel
Damien Voyer
  • Fonction : Auteur
  • PersonId : 841634
The first terms of a multiscale expansion are introduced to tackle a magneto-harmonic problem in a bidimensional setting where the conducting medium is non-magnetic and has a corner singularity. The heuristics of the method are given and numerical computations illustrate the obtained accuracy.
EddyCurrentCorner.pdf (123.79 Ko) Télécharger le fichier
hal-00549380 , version 1 (21-12-2010)
  • HAL Id : hal-00549380 , version 1
François Buret, Monique Dauge, Patrick Dular, Laurent Krähenbühl, Victor Péron, et al.. Eddy currents and corner singularities. Compumag 2011, Jul 2011, Sydney, Australia. pp.électronique. ⟨hal-00549380⟩
652 Consultations
182 Téléchargements
