Optimal stopping for predictive maintenance of a structure subject to corrosion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Institution of Mechanical Engineers, Part O: Journal of Risk and Reliability Année : 2012
We present a numerical method to compute the optimal maintenance time for a complex dynamic system. An early intervention may be uselessly costly, but a late one may lead to a partial/complete failure of the system, which has to be avoided. One must therefore find a balance between these two extreme maintenance policies. To achieve this aim, we model the system by a stochastic hybrid process and propose a numerical method to optimize the maintenance time for this kind of processes. Mathematically, this is an optimal stopping problem. We apply our algorithm to the example of maintenance of a metallic structure subject to corrosion.
hal-00554759 , version 1 (11-01-2011)
Benoîte de Saporta, François Dufour, Huilong Zhang, Charles Elegbede. Optimal stopping for predictive maintenance of a structure subject to corrosion. Proceedings of the Institution of Mechanical Engineers, Part O: Journal of Risk and Reliability, 2012, 226 (2), pp169-181. ⟨hal-00554759⟩
125 Consultations
0 Téléchargements
