Interval observers for linear time-invariant systems with disturbances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2011
It is shown that, for any time-invariant exponentially stable linear system with additive disturbances, time-varying exponentially stable interval observers can be constructed. The technique of construction relies on the Jordan canonical form that any real matrix admits and on time-varying changes of coordinates for elementary Jordan blocks which lead to cooperative linear systems. The approach is applied to detectable linear systems.
auto09-0938.pdf (268.67 Ko) Télécharger le fichier
hal-00555464 , version 1 (25-01-2011)
Frédéric Mazenc, Olivier Bernard. Interval observers for linear time-invariant systems with disturbances. Automatica, 2011, 47 (1), pp.140-147. ⟨10.1016/j.automatica.2010.10.019⟩. ⟨hal-00555464⟩
482 Consultations
1616 Téléchargements
