T-coercivity for scalar interface problems between dielectrics and metamaterials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2012
Some electromagnetic materials have, in a given frequency range, an effective dielectric permittivity and/or a magnetic permeability which are real-valued negative coefficients when dissipation is neglected. They are usually called metamaterials. We study a scalar transmission problem between a classical dielectric material and a metamaterial, set in an open, bounded subset of R^d, with d=2,3. Our aim is to characterize occurences where the problem is well-posed within the Fredholm (or coercive + compact) framework. For that, we build some criteria, based on the geometry of the interface between the dielectric and the metamaterial. The proofs combine simple geometrical arguments with the approach of T-coercivity, introduced by the first and third authors and co-worker. Furthermore, the use of localization techniques allows us to derive well-posedness under conditions that involve the knowledge of the coefficients only near the interface. When the coefficients are piecewise constant, we establish the optimality of the criteria.
BoCC10b-HAL.pdf (2.61 Mo) Télécharger le fichier
hal-00564312 , version 1 (08-02-2011)
hal-00564312 , version 2 (16-05-2012)
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel, Patrick Ciarlet. T-coercivity for scalar interface problems between dielectrics and metamaterials. ESAIM: Mathematical Modelling and Numerical Analysis, 2012, 46, pp.1363-1387. ⟨10.1051/m2an/2012006⟩. ⟨hal-00564312v2⟩
443 Consultations
414 Téléchargements
